Escort GT Stage Rally Car | Ford Escort Owners Association (FEOA)
Discussion in 'Introductions' started by Russell Senior, Jul 31, 2020 at 12:01 AM.
  1. Russell Senior
    Russell Senior New Member
    4
    Greetings.
    I have a 95 escort GT mostly prepped for stage rally. Since the car is old enough to rent a car, I'm having trouble sourcing performance parts for racing on gravel. I'd like some suggestions, if you have any, for suspension and brakes. I've reached out to a few motorsports companies to see what they have, but I thought maybe I could tap the wealth of knowledge here.
    On a scale from 1 to 10 where 1 is stock and 10 is Ken Block money on an escort Cosworth, I'm looking for between 4-6 level of performance. Or maybe $1500 on suspension and $500 for pads/rotors, if that helps.
    Let me know if you have any suggestions.
    Thanks.
  2. 88ESCORTV6
    1,272
    255
    333
    Hawkesbury Ontario
    Phantom Grip <---- start there
    BPT Swap <------- 200 HP Easy
    This would be where to start for most power for the cash.
  3. austin86
    890
    299
    78
    Ohio
    A Phantom grip wouldn’t be a good idea for a rally car. A true lsd would be ideal as a PG would damage a trans under rally conditions unlike drag racing.
    I cant help much for a 95, but I know they are a Mazda platform so using mazda parts is doable.
    But I do know ground control has a coil over kit for the car.
  4. 88ESCORTV6
    1,272
    255
    333
    Hawkesbury Ontario
    I use a phantom Grip on dirt Oval Racing and 1/4 and no problem
  5. Russell Senior
    4
    Thanks, this isn't flat ground though. I'm going over rough road and sometimes getting airborne. The previous owner of my car ran cheapo KYB's and said it was fine, but that's really low rent in my opinion. However, I don't want to spend more than a couple grand....
    Here is a video of one of the events I will be doing:
    I'll check out ground control. I appreciate the comments. And yes a limited slip is in my future, I'll probably go quaife and Lincoln-locked, depending on the event. A turbo is also in my future, but that puts me in a different class, and I want to start out easy.
    austin86 and Pyoro like this.
  6. Russell Senior
    4
    Actually, here's a better video (you can hear the navigator)
  7. austin86
    890
    299
    78
    Ohio
    Dirt Oval Racing and 1/4 is not rally racing. A PH would shred up in a rally car leaving shards in the diff/tans.
