Hey Guys, My Idea is to fit Mustang calipers and Contour svt rotors to my escort, I was going to put them on my Merkur but putting them on the escort is just too darn exciting. I was wondering if anyone had a front right steering knuckle that I could buy cheap for expirimental purposes, since I will have to cut off the original perches that are cast in to hold the pads. I also plan on milling the back surface on the knuckle flat to make two large bolt holes and a mating surface for an adapter bracket, this adapter bracket will mount the mustang bracket which is what holds the caliper and pads. The calipers are an Aluminum(Wow, type ALUMINUM with one finger and see how many X's are produced!) Dual piston design, both pistons on one side with slider pins, and they fit a 1999 ford mustang, non cobra, same for the brackets, and the rotors are from a contour svt, I think 1999 works as well, they are hubcentric and have the same bolt pattern as an Escort and are just a hair under eleven inches, if the brake swap is successful, they will not fit under any stock first generation wheels. And I know I am getting well ahead of myself but if I can do the front I will tackle the rear, but Mr. T. Bird will have to help me out with that one.
Alex
Alex
