Epoxy Filler? | Ford Escort Owners Association (FEOA)
Epoxy Filler?
Discussion in 'General Discussion' started by krux303, May 19, 2020.
  1. krux303
    krux303 FEOA Member
    46
    6
    8
    I'm looking to port my intake manifold on a zx2. The runners have valleys that could be filled with some kind strong epoxy and then ported. The legend Johnp on teamzx2 use to do this.
    Any thoughts what would work? I have nitrous as well.
    Sent from my LG-H872 using Tapatalk
  2. austin86
    685
    207
    58
    Ohio
    are you sure it was epoxy and not brazed?
  3. krux303
    krux303 FEOA Member
    46
    6
    8
    Its a plastic manifold and I believe Johnp used a epoxy when I last spoke with him.
  4. marclar
    8,881
    505
    seabeck WA
    can you elaborate on this a bit? the manifold is made of glass fiber reinforced thermo plastic. its very hard to get anything to adhere to it.
  5. krux303
    krux303 FEOA Member
    46
    6
    8
    A legend named Johnp on teamzx2 used a filler on top of the pastic runners. After the filler dried, you would grind the ports open to removed as much material to open the ports. Good results of 6-8hp.
  6. austin86
    685
    207
    58
    Ohio
    I always forget that.
  7. marclar
    8,881
    505
    seabeck WA
    ok that makes sense. there are some weird angles built into the cast. not for a lack of trying id assume on fords side, just hard to make the molds.
