Engine - Engine swap | Ford Escort Owners Association (FEOA)
Engine Engine swap
Discussion in 'Engine Swaps' started by Mikeholt, Aug 2, 2019.
  1. Mikeholt
    Mikeholt New Member
    I have an 1988 EXP with a 1.9 EFI ho engine. I'm having a hard time finding a 1.9 and I want to know what would be a good swap for more horsepower. It is a dirt race car
    austin86 likes this.
  2. Tnashua
    Tnashua Gearhead / hot rodder with a soft spot for Scorts
    1,045
    233
    213
    Oskaloosa, IA
    Hello Mike,
    Where are you located? There are places to find 1.9's... I have a rebuilt 1.9 sitting in the garage & enough blocks/cranks/rods/pistons to put a few short blocks back together. The cam in the rebuilt engine is a hydraulic circle track cam from SpeedPro. :)
    My parts are in South Central Iowa...
    I don't know what your track rules are- our 4 cylinder class rules are pretty strict about modifications... If you could get away with a different block, are allowed to run aftermarket ecu's and can pull the funds together to do so- you could stick a 3rd gen 2.0L SPI Shortblock & a ZX2 trans w/ a 2nd gen GT clutch in it- clean up (port match, bowl blend) the HO head, install some head studs & put together a MSII to control the thing... I'd sell you the camshaft if you can't find one on ebay.
  3. Mikeholt
    Mikeholt New Member
    I'm in Winston Salem n.c.
  4. Tnashua
    1,045
    233
    213
    Oskaloosa, IA
    Do you have to have a stock ecu? Do you have to have an engine that was factory installed in your car?
  5. austin86
    austin86 FEOA Member
    459
    77
    43
    Ohio
    I have one. setting in my garage
