I've had this issue for a while. When I have less than a half tank and dip a hard right, the engine will sputter and sometimes stall after a turn. Depending on G-force and duration of turn the engine will fail to restart for several seconds. Nothing more embarrassing that beating someone through a corner had have them catch up because your cranking a trying to restart. It seems as if I lose fuel pressure and sucking air into fuel system due to fuel sloshing. I have made to scort handle incredibly well and i can easily bust turns 2-3 times normal limits. I believe that the pick up screen has fallen off, or I just shift the fuel too hard. I have considered pulling pump (checking everything out of course), but see if I can fabricate a baffle to alleviate this problem. I was wondering if anyone else has had a similar issue, or had any suggestions. Your input would be appreciated.
