1 - 2 of 2 Posts
There's a screw near the dashpot of the rotator cuff of the throttle. That's how you adjust it. You can also adjust bypass air using the bypass valve on the VAM. (needs to be drilled out, stock setting is 2.25 turns up from bottom)
1 - 2 of 2 Posts
