Hello, I'm new to this site and I really hope you could help me try and figure out the problems with my girlfriends car.
She has a high mileage 1999 Escort and in the ongoing attempts to try and have it inspected it keeps spewing out fault codes. The auto-repair shop who's done the work on it so far hasn't been able to fix it, latest attempt was replacing the battery and alternator. The Fault Codes were P0325 and P0460(I hadn't been told which codes etc at that point, so she went by the mechanics advice alone).
Prior to this it's also had the following done:
Remove throttle body and clean EGR passages and install Fuel Pressure Regulator and Fuel Filter
Install DPFE
Prior to this work, the car was displaying the codes P0401 (Exhaust Gas Recirculation Flow Insufficient Detected), P0190 and P0193.
After this, according to the auto repair place, it displayed the P0325 and P0460 mentioned above, as said, they suggested replacing the alternator and battery, which was done, and during the last check it now produced the following fault codes: P0190, P0193, P0325, P0460. ..so pretty much the same as before spending 100 and some bucks on an alternator and a battery.
The problem is I'm not a mechanic, nor am I very familiar with USDM Fords or Fords at all for that matter (I'm overseas atm), I was hoping someone might know what could be wrong, any help at all will be greatly appreciated, as we can't really afford a new car at this point, nor more costly repairs. ($900+ spent so far).
Can anyone give any advice? It should also be mentioned that the codes might've been there a long time (well over a year, due to a dishonest seller) and that the battery that was in it prior to the latest change was too big (physically, I'm trying to figure out what the actual difference was though), thanks again for any suggestions.
PS!
I looked at a list posted by a member here with all the fault codes, which gave me this (That way you won't have to look it up yourselves
P0190 - Fuel Rail Pressure Sensor Circuit Malfunction (FRP) The comprehensive component monitor (CCM) monitors the FRP sensor to the PCM for VREF voltage. The test fails when the VREF voltage from the PCM drops to a voltage less than a minimum calibrated value. VREF open in harness.
VREF open in sensor.
VREF open in PCM.
Verify VREF voltage between 4.0 and 6.0V.
P0193 - Fuel Rail Pressure Sensor Circuit High Input (FRP) The comprehensive component monitor (CCM) monitors the FRP sensor circuit to the PCM for high voltage. If voltage were to fall below a calibrated limit and a calibrated amount of time during testing, the test will fail. FRP signal shorted to VREF or VPWR.
FRP signal open (gasoline only)
Low fuel pressure (NG only)
Damaged FRP sensor.
Damaged PCM.
High fuel pressure (caused by damaged fuel pressure regulator) NG.
A FRP PID value during KOER or KOEO less than 0.3 volts for gasoline or 0.5 volts for natural gas vehicles (NG) would indicate a hard fault.
P0325 - Knock Sensor 1 Circuit Malfunction (Bank 1)
P0460 - Fuel Level Sensor Circuit Malfunction The PCM monitors the fuel level input (FLI) circuit for electrical failure. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified fuel fill percentage in the fuel tank. Empty fuel tank
Fuel pump (FP) module stuck open
Incorrectly installed fuel gauge
Damaged instrument cluster
CASE GND circuit open
FLI shorted to VPWR
Damaged PCM
Overfilled fuel tank
Fuel pump (FP) module stuck closed
Damaged fuel gauge
FLI circuit open
FLI circuit shorted to CASE GND or PWR GND
CSE GND shorted to VPWR
Monitor FLI PID and FLI V PID in key ON engine running. FLI PID at 25% fill (with none matching fuel gauge) and FLI V PID less than 0.90 volts [for FLI PID at 75% fill (with none matching fuel gauge) and FLI V PID greater than 2.45 volts] indicates a hard fault.
Install DPFE
PS!
VREF open in PCM.
Damaged FRP sensor.
Damaged PCM.
FLI shorted to VPWR
Damaged PCM
Damaged fuel gauge
FLI circuit open
