1 - 3 of 3 Posts
Hey i have a 95 hatch with the 1.9, and i was thinking about doin a 90-95 engine swap with the 1.8 DOHC. Will my tranny match with the 1.8, is the ecu just a plug and play thing and will the gauage cluster from a GT just plug in to the dash of an LX? I really want to make my 1.9 fast but if i can do the swap's then ill do them while i have access to the new parts.
ull have to swap, axels, tranny, ecu, wiring harness, engine, and that might be it....
much easier to swap a 2.0 from a 97. just have to swap engine. ull then have 110hp/125lbs-ft torque vs stock 88/110. you can always add clutch, ignition, cam, lightned flywheel, underdrive pulley, cam gear to the 2.0.... later :) enjoy
you will need alot more than that for the GT swap. You will need pretty much a whole front clip of the GT and then swap everything, unless you dont want A/C from the GT clip into your engine bay. Every wire, sensor, everything.
1 - 3 of 3 Posts
