Suspension - Energy Suspension Sway-Bar End-Links/Bushings | Ford Escort Owners Association (FEOA)
Suspension Energy Suspension Sway-Bar End-Links/Bushings
Discussion in 'Part Numbers' started by Ocramzeej, Jul 14, 2017.
  1. Ocramzeej
    Ocramzeej FEOA Donator
    125
    27
    178
    Louisville, KY
    For those looking to get some nice polyurethane Sway Bar End-Links/Bushings, here are the part numbers you'll need. Please note that if you have a GT or a Wagon (or a GT/Wagon rear sway bar), the rear bushings will have to be drilled out to 21mm, as these bushings only come in 19mm. Also, the front bushings will work for a ZX2/3g escort as well, however the rear bushings will not fit a stock zx2 or 3g escort, as those years/models only came with a 13mm rear sway bar.
    Front Bushings/End-Links: Energy Suspension 4.5141
    Rear Bushings/End Links: Energy Suspension 4.5140
    Note, you'll generally find these with either an R or a G after the numbers, this only denotes the bushing colors, between Red or Black. The bushing sizes are still the same.
  2. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,435
    1,133
    Vancouver Island, Canada
    I just checked the Energy Suspension site and 4.5141 is listed as discontinued.
    4.5140 is shown as still available.
  3. Ocramzeej
    125
    27
    178
    Louisville, KY
    Weird. I was able to find mine on Ebay about a year ago, may be able to still find them there every once in a while.
