Energy Suspension motor mount inserts | Ford Escort Owners Association (FEOA)
Discussion in 'Part Numbers' started by 88scortgt, Apr 28, 2009.
  1. 88scortgt
    88scortgt FEOA Member
    750
    166
    Elkhart, IN
    Here is proof that AutoZone can get these inserts. Part # is 4.1105G (black) or 4.1105R (red). I ordered them on Sat., and picked them up on Tues.
    [​IMG]
    [​IMG]
    [​IMG]
  2. EscorGo
    EscorGo FEOA Donator
    3,006
    139
    213
    Wichita, KS
  3. kendogg
    kendogg Guest
    169
    Which mount is this for? Is it for all of them?
  4. 88scortgt
    750
    166
    Elkhart, IN
    The inserts are for the two lower mounts on the front and rear of the transmission.
  5. kendogg
    kendogg Guest
    169
    So thats a whole kit for $25? Doe sit fit the 2nd gen 1.9? Sorry for the hundred questions, I need the rear lower trans mount most, and if thats what I need, I'll be ordering them from Amazon tonight
  6. 88scortgt
    750
    166
    Elkhart, IN
    Sorry to say, but they only fit the 1.8 5-speed.
  7. kendogg
    kendogg Guest
    169
    Well, thanks for the clarification :)
  8. white-lightning
    white-lightning FEOA Member
    2,896
    186
    Salem, VA
    If the 1.9 is a manual it will work. They will work on any 5-speed escort 91-03.
  9. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    yep, can't remember the part number off hand, but I have front and rear inserts on both of my Escorts.
  10. kendogg
    kendogg Guest
    169
    OK, sweet, my car is a manual. Thanks!!!
  11. ciento44
    ciento44 FEOA Member
    1,588
    186
    Indianapolis
    i picked these up on Tuesday as well. :)
  12. TexasTracer
    TexasTracer FEOA Member
    4,694
    16
    188
    Sunnyvale, Texas
    Also the rear mount will work on auto's. Just not the front mount it is different.
  13. 88scortgt
    750
    166
    Elkhart, IN
    I apologize, kendogg.
    I posted the wrong info on what the inserts fit. I thought I read somewhere on FEOA they would only fit the 1.8 5-speed in the 2nd gen Escort.
    I thank everyone else for correcting my mistake.
  14. kendogg
    kendogg Guest
    169
    It's cool. Thankfully, clueless people like me ask ALOT of questions, verifying ALL of the info for the rest :)
    Now, if only somebody at zxtuner.com would answer my emails.......
  15. kendogg
    kendogg Guest
    169
    Autozone can infact order anything from Energy Suspension. I just ordered 3 p/n's:
    1.1105G - Motor Mount Inserts
    1.1106G - Shift stabilizer Bushing
    1.10105G - Steering Rack Bushings
    All should be here Thursday I did not want to wait, and since none of the online Escort vendors I emailed have returned my emails, I just bit the bullet and decided to give AutoZone my money :(
  16. kendogg
    kendogg Guest
    169
    Got my bushings from AutoZone. Energy Suspension, all black.
    4.10105G - Rack Bushings - $10.99
    4.1105G - Motor Mount Inserts - $25.99
    4.1106G - Shifter Bushing - $14.99
    3 days wait time, can't argue with that. And, I bought new motor and trans mounts as well to go with the 2 inserts.
  17. kendogg
    kendogg Guest
    169
    OMFG what a night & day difference just replacing the 2 mounts on that one brace/cradle (the front lower motor mount, and the rear trans mount) with the ES inserts. Car is smooth as can be now.
  18. ciento44
    1,588
    186
    Indianapolis
    ^bump.
    These still smooth?
    I'm convinced they're 100% useless.
  19. kendogg
    kendogg Guest
    169
    Well, they aren't going to cause any vibrations because there's no connection of poly to the chassis. All they are is a movement limiter. On a car thats driven hard, they'll increase the life of the rubber mounts, reduce engine movement, while still providing the damping and vibration absorbtion of the stock rubber mounts.
  20. ciento44
    1,588
    186
    Indianapolis
    Uhmmm.....
    No.
    They're going to cause a buttload of vibrations, don't tell me they don't. Every single car i've ever driven or ridden in with inserts has vibrated worse than a sybian.
    They are SUPPOSED to limit movement. And that, they do. For two weeks. Then they give out.
    They reduce engine movement, while eliminating at least 80% of the stock rubber mount's capability to damn vibrations.
    It's pretty sweet after two weeks of install when you still have all the vibration, and NONE of the performance.
