Electrical - electrical difficulties | Ford Escort Owners Association (FEOA)
Electrical electrical difficulties
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by JobeaQuartz, Jan 25, 2020.
  1. JobeaQuartz
    JobeaQuartz FEOA Member
    24
    After installing a new speaker, I started to smell electrical burning in the cabin, around a day after I noticed my head unit stopped working, I've since resoldered the wiring harness, not confident that will fix anything, but I can hope. My car does not play a tone when my lights are on with the door open, or when my key is in the ignition with the door open. The dome light has also stopped working, anything I should check, like fuses?
  2. pextor
    pextor Moderator Staff Member
    6,032
    857
    Lancaster, pa
    Is it the factory stereo?
  3. JobeaQuartz
    24
  4. pextor
    6,032
    857
    Lancaster, pa
    You can check the fuses and you'll probably find one blown - the interior fuse.
    If you replace it it's probably going to blow again.
  5. JobeaQuartz
    24
    yeah, I'm getting a different head unit, mine seems to be cheap
  6. JobeaQuartz
    24
    replaced the fuse, everything worked, the moment I plugged in the head unit, it stopped. Last time I use a boss audio head unit
