My ebrake stuck all last winter so I had the local mechanic replace the ebrake cable on the left wheel because he said there was a kink in it.(this guys a good guy, it'snot his fault) The problem is that now it is sticking again. Seeing that it's cold again. I'm thinking that it is the caliper. The problem is that it doesn't stop after the wheel starts moving, it just keeps rubbing the brake on the disc. It was so bad that the rotor was glowing bright red when it stuck about 4 days ago.
