1 - 12 of 12 Posts
for managment im going to run this and pricing around i saw on ebay you can get if for 270 bucks. Im wondering if anyone knows how the company/store can sell the apexi safc2 for 270 bucks when the lowest price anywhere else is 350?
Administrator
WOW... if your going to spend that much money on a crappy afc, spend the extra maybe hundered dollars and get the MEGASQUIRT, you will kick yourself in the end if you get the s afc. the MS is SOOOOOOOOOOOOOOOOOOOO much better... please theck the fuel system part of teh "escoort turbo info" for more info on what the megs squirt does...
basically its completely standalone.. you can MAKE your OWN FUEL AND TIMING MAPS. id like to see a safc do that. plus you dont need the MAF because the MS has its own built in MAP sensor so you can do anything you want to the intake.
Why would a Megasquirt cost more? :?
[edit] Just realized that you're doing your MS for a 1st Gen. Converting a 2nd Gen LX to MS would be ultra cheap since all the extra stuff you need is already on the motor.
Administrator
if you have a crank sensor you can put MS on . actually you can put it on any motor by mounting thetrigger wheel from the crank pully on whatever pully your using. then mount the crank sensor, plug the edis, coil, pack a.nd the ms together and fire it up
ummmmm doesnt the APEXI just let you controll the fuel curve? I went to thier web site and thats what I got from it, maybe I just read something wrong but www.esortfocus.com sells an ADJUSTABLE FUEL MIXTURE CONTROLLER for 79.99 I think. So if you just wanna controll the fuel/air mixture that might do it on a budget. Maybe the APEXI does alot more but I dont know :D But both adj the fuel curve to your liking
Administrator
im tellin ya. spend the extra 30$ and get a totaly customizeable stup. why spend 30$ less andnot be able to control your timing, and use any injector. the ms has fail safe backups and the apexi just changes the curve slightly.
do what you will
Onegimp said:
No, it lets you trick the factory fuel curve.
Thank you!
Everybody trys to find shortcuts but they don't read up on what they think they are talking about and they think they can do things the cheep way. Research is very important, that's why I read a whole lot more than I post. I get tired of people shoting their mouths off and I don't want to be classified as one of them.
Sorry TracerX if yoa seem like Im shooting my mouth off but Im not. I went to the APEXI web page and then the escortfocus.com page looked at what they both did and it seemed like they let you controll, not trick the fuel curve. I even mentioned I might be wrong but that is what i got from the description. Wouldnt say thats shooting my mouth off. Maybe shooting my keyboard though :D
Tracer-X said:
Thank you!
so if ya think about it, i'm basically researching my turbo project/suspension setup for about 8 months before i even buy anything :lol:
1 - 12 of 12 Posts
