1 - 5 of 5 Posts
is it idling ok when its in park or does it sputter then too? cuz i had a problem similar to this i would keep having to keep it in neutral and keep hittin the gas.. all was wrong with mine was somethin needed cleaned
sethxtreme said:
what has to be cleaned? i dont really know what ur referring to...
Throddle body, Idle Speed Control, Air Flow Sensor, and perhaps the EGR valve. It would also help to clean and add new dielectric grease to the electrical contacts on the Air Temp sensor, Air Flow Sensor, and Coolant Temperature Sensor.
1 - 5 of 5 Posts
