Fuel - Dual Weber IDF Carburetors on a 1.9 H.O! (work in progress) | Page 2 | Ford Escort Owners Association (FEOA)
Fuel Dual Weber IDF Carburetors on a 1.9 H.O! (work in progress)
Discussion in '1st Gen 1981-1990 CVH' started by nineteeneightyeight, Mar 7, 2014.
  1. nineteeneightyeight
    nineteeneightyeight FEOA Member
    400
    54
    278
    Holgate, Ohio
    I am actually really glad you mentioned the timing because it probably would have been overlooked for the first initial test runs. Maybe I can lock a pin or something to pre-advance it so the advance range is narrowed, and set the initial and final advance after that. I wonder if they ever made different springs that fit these distributors...
  2. JOEG5982
    JOEG5982 FEOA Member
    361
    79
    178
    Pay attention to that distributor and its timing. I "melted" a motor or two before figuring that out!
    For distributor springs, you will note that the OEM distributor has a light one and a heavy one. If you can't find lighter ones, just use two of the light ones--the ones with thinner wire.
    We tig welded the slots and filed. I suppose if you can take the shaft apart, clean the slot, you can epoxy and file for the same effect. Not sure if I would trust the epoxy for long, however.
  3. nineteeneightyeight
    400
    54
    278
    Holgate, Ohio
  4. JOEG5982
    361
    79
    178
    Maybe...but note ad says: **Distributor must be locked out with no internal advance.**
  5. nineteeneightyeight
    400
    54
    278
    Holgate, Ohio
    Yeah I would put one of my spare EFI distributors on probably, for a fixed trigger.
  6. nineteeneightyeight
    400
    54
    278
    Holgate, Ohio
    I am only running that mechanical advance distributor now because I put a stock style 2 barrel carb on there for now.
  7. JOEG5982
    361
    79
    178
    That's a possible solution.
