Drum screws | Ford Escort Owners Association (FEOA)
Drum screws
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by Kixthecereal, Mar 22, 2020.
  1. Kixthecereal
    Kixthecereal New Member
    I posted this question in the wheel and brakes forum too, but I am redoing the drum brakes on my 97 LX and when I took the tire off, the two Phillips screws that hold the drum on weren't there. Do I need to find replacements? Do I absolutely need them?
  2. zzyzzx
    14,871
    1,147
    You don't need them.
  3. pextor
    pextor Moderator Staff Member
    5,874
    765
    Lancaster, pa
    definitely not needed. The wheel holds the drum on.
    Kixthecereal and zzyzzx like this.
  4. Kixthecereal
    Cool. Thanks guys.
  5. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,238
    1,003
    Vancouver Island, Canada
    I like having them, since they are the same thread (M8) as the two threaded holes in the drum, allowing them to be used as jacking screws to force the drum off it is a little stuck.
    However the threaded drum holes are often full of rust, preventing the screws from threading in properly. When I have the drums off I run an old tap through them and then put a bit of grease in so that they are usable in the future.
    rbailin likes this.
  6. pextor
    5,874
    765
    Lancaster, pa
    Those Philips head screws were never the best for getting the drums off. I used a different screw for that..... I forget which one, but something under the hood with a hex head for a socket.
  7. Joey_Twowagons
    2,238
    1,003
    The Philips screws probably aren't so good because you live in the rust belt.
    It sure is nice out on the wet coast, the drums generally can be removed by hand, no pounding, prying, jacking screws etc. required.
    rbailin, zzyzzx and Bas1c973sco like this.
  8. rbailin
    rbailin FEOA Member
    1,238
    372
    333
    If you want to buy them, use Dorman 13823 blister pack ("Help!" carded products) which contain 8 short M8 screws with a P3 philips head, just like the OEM.
    Joey_Twowagons likes this.
