I have a 1999 SE Sport with the 2.0 SPI SOHC engine (VIN P). I have read alot about how the number four cylinder likes to drop the valve seat. I bought the car in 2017 with about 80,000 miles on it. It now has 116,000 miles and running great (2022). Not knowing the service history, shortly after I bought it, I replaced the timing belt and water pump. The old timing belt looked fine, but the water pump did not. The water pump has a backing plate on the impeller and it was severely corroded to the point where it looked like swiss cheese. What I suspect may be happening is that metal particles from dissolving impeller along with your usual crud after 80k miles or so are clogging up the cooling passages in the head aroung the number four cylinder, or any of the other cylinders for that matter.This could potentially cause uneven heat buildup in the head, causing it to warp enough to pop the valve seat out. Before I changed the water pump, I flushed the cooling system with radiator flush (Blue Devil for example). It looked like it originally had the Ford Gold coolant. I replaced it with universal green coolant and it has been fine, though I offer no guarantees. It runs great. If it blows, I will post it. Hope this helps!
MAGA
MAGA
