OK so Last saturday I was bored as hell so went to the local car audio Shop and Bought a set oc Type S Components because when I throw in the solo X I will need more vocals. So I spent $280canadian on components and 25feet of speaker wire.
Then I went home and spent 6 hours in the not heated garage. MAn my toes were frozen like rocks, I couldn't bend them.
And if anyone says 6 hours holy cap thats long screw you...
I had to:
-mount the tweeters
-Run wire to the back of the car
-take out rear speakers
-mount component set
-mount crossover
-take off panel and cut rear door holes for the coaxils
-fix my driver door lock
-set amp
-make sure all connections were all good.
-drill holes for coaxils
-connect crossovers
-run the wire through the doors to crossover
Anyways here is the end result and it sounds aweome mind you.
Plus various pictures of other things going in next spring
I have extra grills of those style... If I can find them, I could give them to someone... as for the money that you saved me... possibly some time, but not only am I going to be adding the extras in the front, I will be keeping the rear ones in, as well as adding a set in my rear doors.
Whitie which ones the ones in the rear of the panel or the front of the panel, I ones on the rear speakers of the panel are suppose to go on the front speakers but They don't clear so I stuck them on the other speakers. I just switched the grills.
yeah if i could take a video that had decent quality then I would show you but you live to far away. the front stage is great. ill see what i can do for a video.
I'm was going to do the 2 in the front door... but after seeing my lack of room in my 4DR... it's going to take some cutting of the frame, which I don't really know if I want to do.... we will see.
never heard Earthquakes ... the biggest problem with em ( probly the only one) the tweeters are a tad to present .. im gonna blow my head off every time im gonna crank up the volume
i could put em faceing the back... that could work
hell yeah.. but for now my little 760W pioneer with my blaupunkt 12" is plenty... i'll surely add on to it but not this winter.. i'll do with all this .. anyways got a buddy of mine wanting to buy the amp sub and box for 350$ ... resonable i think
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
FEOA Forums
834.1K posts
18K members
Since 2002
