Thanks Trencher. I just tried your mod last night and it worked, with a slight twist.
For some reason, I had a little more congestion under my steering column than your pics showed, and I didn't have enough clearance to 'clock' the white switch assembly around past the opening for the little nub plunger.
So, I took a cable tie and tie'd the nub plunger down into the 'off' position. I then rotated the white switch assembly back to it's orignal position and even had enough space (with the cable tie) to put the old screw back (just to keep everything snug).
Trim back in place and I was good to go. Ahhh, blessed silence! No more of my Scort reminding me my door is open....seriously, are we drivers too lazy to open our eyes and LOOK for an open door, that we need an audible alarm???
Thanks again!
Thanks again!
