DOHC BP turbo club members | Page 3 | Ford Escort Owners Association (FEOA)
Discussion in 'Forced Induction & Nitrous' started by neuspeedescort, Aug 18, 2005.
  1. EGTERIC
    EGTERIC New Member
    2,417
    Glendale Hts. IL
    yay i can post here now finally
    95 EGT
    GTX 18x11x3FMIC spec stage 3 clutch
    Megasquirt!!!!
  2. atomicEGT
    atomicEGT Guest
    198
    Version 2.0
    95 EGT
    BPD
    Haltech
    etc
  3. turpro
    turpro New Member
    290
    the nati
    Woooohooooo. Finally.
    Bp05 motor
    Bp05 intake manni
    Bp26 ecu
    Bpt exaust manni
    Bpt Y code VAF
    Ft2 injectors
    F2t ic
    F2t vj11
    Supra bypass valve
    Getto fabuloud piping(temp till fmic gets here in a couple weeks)
  4. uglyducklingescort
    uglyducklingescort New Member
    997
    Tulsa, OK
    Dang I thought I put something up here a long time ago....
    GTR Intake
    GTR Rods
    ACL "Race" bearings
    Block 1mm oversize bore
    Weisco Forged aluminum pistons
    Everything Fully balanced within .5g
    VJ23 Turbo (GTR)
    Electronic boost Controller
    HKS SSQV BOV
    AEM Wideband
    BP26 Cams
    BP05 Head
    460cc Low Inpedance Inj
    Microtech Standalone Engine Management
    Spec Stage 2+ Clutch
    2.5" Stainless Catless Exhaust, Flowmaster 40 series
    Walboro 255Lpr Fuel pump
    Large Bar and Plate IC 2.5 piping
  5. Zachary
    Zachary Guest
    GTX motor
    95 EGT
    BP05 motor
    BP26 Intake manifold
    BP22 Throttle body
    BP26 Cams
    BP01 Main Bearing support plate
    and their lots others ..[​IMG]
  6. stylin93wagon
    stylin93wagon Guest
    478
    bp05 motor
    gtx ecu
    4 wire tps
    vj-20
    bp26 manifold
    gtx intake (ported)
    gtx injectors underdrive pulley
    stage 2 clutch kit
    type rs bov(recirced)
    2 7/8 wraped down pipe
    2 1/2 cat back
    magna flow
    safc 1
  7. Zachary
    Zachary Guest
  8. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    95 GT
    bp26 exhaust manifold
    4 wire tps
    vj20 turbo
    Spec stage 3 clutch
    o2 housing back 2.5 in exhaust
    bp26 ecu
    U code vam
    b code vam
    Glowshift wideband
    Fmic 2.5in piping
    Greddy knockoff bov
    Mx6 GT injectors
    Tapped oil pan
    11 Degrees timing
    NGK plugs
    Borg warner Copper contact distributor cap
    Duralast rotor button
  9. dok33
    dok33 New Member
    1,021
    Austin, TX
    [​IMG]
    [​IMG]
    1989 Festiva LX GRM $2009 Challenge Car
    BP swap out of a '94 EGT, Capri XR2 trans/axles, custom mounts
    Miata ebay manifold, DSM T25 with custom adapter for standard T25 manifold
    Open downpipe :twisted:
    SRT4 intercooler, MKIII Supra IC piping and BOV
    Megasquirt 1 (MSnSe) Tuned
    440cc Supra injectors
    Aspire suspension/brake swap w/Civic ebay coilovers
    Currently running 8psi, should have some 1/4mi numbers this weekend...
  10. escortfan
    escortfan FEOA Member
    823
    166
    Burl.Ontario
    Im in, gigidy!!
    BP05 engine
    BP26 Exhaust manifold
    BP26 ECU
    BP26 Injectors
    Y code VAF
    Corksport downpipe
    Custom 2.5" Exhaust catless mufflerless lol....
    2.5" IC and piping
    HKS BOV
    HKS Turbo timer
  11. Silex
    Silex New Member
    863
    Brampton , ON
    :jive: I finally join the club
    1995 Escort LX ( now a 1996 Escort Wagon 8) )
    BP05 w/5spd
    BP26 ECU ( currently running the EGT ecu until mega squirt arrives )
    BP26 Exh. Manifold
    VJ20 Turbo
    DSM Bov
    Custom Charge pipe
    FMIC
    Stg 3 Clutch
    MX6 GT injectors ( 325cc )
    MX6 Catback pipes
    RX7 Vaf
    Bosal Brospeed Muffler
    DD on 8psi , 12psi for the track :demon:
  12. Sleepy323
    Sleepy323 New Member
    82
    mazda 323
    Bp05 motor/5 spd
    bp26 manifold
    vj14 turbo 7-8psi
    mazda 626 fuel pump
    greddy type rs blowoff
    2.5in down pipe
    2.5 exhaust
    wsp2 pan
    srt4 intercooler
    custom intercooler piping
    stock injectors
    stock egt n/a computer with a custom map
  13. yrogerganai
    yrogerganai New Member
    47
    Niagara, Ontario, Canada
    -95 Lx swapped to GT and Boosted 18psi.
    T3 Turbo
    running megasquirt
    rx-7 tII injectors
    wahlbro 255 fuel pump
    rod millen grind cams
    Greddy blowoff
    wideband o2
    -93 power roof and seatbelts boosted 9psi.
    corksport manifold
    IHI VJ11 turbo
    stock harness
    stock computer
    rx-7 Maf tuned
    rx-7 turboII injectors
    HKS Blowoff
  14. Guest
    Guest Guest
    Suppose I belong here too!
    95 EGT
    BP Motor
    GTX Turbo
    GTX Ex. Mani.
    GTX In. Mani.
    GTX Inlet pipe
    GTX (Green) Injectors
    EGT ECU
    EGT Harness
    Homebrew CAI
    Homebrew FMIC
    Homebrew Downpipe
  15. Spoolinscort
    Spoolinscort New Member
    38
    91 egT
    Miata turbo manifold-t25 turbo- obx fmu 12:1- eBay intercooler kit- custom down pipe- probe gt 330cc.
    Question. Do I need to replace my rad. With the civic half size? With my set up?
  16. Guest
    Guest Guest
    Wrong type of escorts allowed here, so I raped this post
  17. crazy-eh666
    crazy-eh666 New Member
    47
    1995 EGT
    -stock gtx motor
    -255 fuel pump
    -cx racing fmic
    -hks ssq bov
    -turbosmart turbo timer
    -ghetto boost and oil guages
    -spec stage 3
  18. agrowagon
    agrowagon FEOA Member
    605
    266
    Okeechobee, Florida
    Just joined the club
    Bp05 engine
    T3t4 .50 trim a/r.63
    Bp26 Mani
    Fmic 2" piping
    Rs type bov
    U code vam
    Bp05 intake
    Bp26 ecu
    Mx6gt injectors
    Adjustable fuel pressure regulator
    38mm external wastegate
    38mm wastegate dumptube
    2 1/2" down pipe
    Manual boost controller set for around 10psi
  19. vtec-this
    vtec-this FEOA Member
    1,577
    6
    288
    Brampton Ontario
  20. Blueescortproject
    Blueescortproject FEOA Member
    189
    11
    268
    Marietta, Georgia
    Been wanting to join this club for many years and now I can finally post here!
    [​IMG]
