1 - 2 of 2 Posts
I have an annoying little oil leak coming from under my distributor. do I just pull it out and change the o-ring? It has never been out and the car is at 116k , so I figured that was the cause. It's a 91 Gt. Do I need any kind of sealer around it?
First, check your valve cover gasket...
Also, I think there is an oring where the cam meets up with the dist. You'll want to check there too, it shouldn't be too difficult.
When you are using a rubber gasket, I've been told that no sealer is necessary.
1 - 2 of 2 Posts
