Distributor gasket/o-ring. Oil in cap! | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by JCraven94, Jan 15, 2020.
  1. JCraven94
    JCraven94 FEOA Member
    173
    37
    88
    Hey guys, so would anyone know the procedure on replacing the dizzy gasket/o-ring? It's been leaking slowly since I bought the car, and today while trying to hunt down a hesitation/irregular misfire I found some oil in the dizzy cap. Anyone know what's involved and where to find the part? Also, would oil in the distributor cause a misfire or hesitation at all? I cleaned all the contacts on the cap and rotor, but nothing really changed. Is it possible the oil in the distributor could be effecting the pickup coil? I'm not sure what would be safe to try and clean it out. Low VOC brake cleaner? Electrical cleaner? Need some suggestions.
  2. marclar
    8,775
    383
    seabeck WA
    there is a seal on the dizzy shaft. often it is not a repairable failure, and most of the time will require replacement of the dizzy unit. often the shaft wears out as well...
    yes it could cause a mis.
    yes anything inside other than air can cause irregular pickup.
    use brake parts cleaner.
    denisond3 and JCraven94 like this.
  3. JCraven94
    173
    37
    88
    Good info, thanks!
  4. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,075
    913
    363
    Vancouver Island, Canada
    I had the internal distributor seal fail on my Mazda B2200 truck, and was able to measure up and by replacement seals online. It was a non-standard size.
    Maybe your distributor can also be fixed this way.
