I was wondering if much changed between the 1991 EGT and the 1994 EGT? Will the steering column out of a 1991 fit in a 1994? Also does the 1994 sit lower or is it just my imagination?
Redlined Man
Redlined Man
Steering column will fit no problem. minor changes between the years, but most parts are still interchangeable. Ride height should be the same, one may have broken springs, it's rather common.Redlined_Man said:I was wondering if much changed between the 1991 EGT and the 1994 EGT? Will the steering column out of a 1991 fit in a 1994? Also does the 1994 sit lower or is it just my imagination?
Redlined Man
