About a year ago, every now and then (once every 3 months) when I would start my car it would run HORRIBLE. Seemed like it was firing on one cylinder at best...terrible vibrations, but no CEL. To fix it, I would turn off the car and restart it until it started smoothly. Once it started smoothly, it would run/drive just fine...never had a problem after it was started.
About two weeks ago, this phenomenon started happening more and more often. And it took more tries to get it to start normally, but still once it was started smoothly, it ran great, drove home fine.
Then this past saturday it happened really bad, I kept re-starting the car...but after a few times of starting and running rough...I couldn't even get it to start at all, it would just crank over...but then after about a dozen tries...sure enough started right up, drove home no problem.
The last time was Sunday, came out of the store..tried starting it ran rough, shut it off and tried again....and I couldn't get it start...and one of the times I was turning it over...there was a "clunk" and then it would NOT turn over any more. It sound like there is some type of interference
...the battery is really strong and when I turn the key there is instantly a heavy clunk from the engine and it won't turn.
This is NOT the little click you get when your battery is dead...this sound like a piston is running into something.
What happened???...I find the facts that there was never a check engine light, and the fact it would seem to "work itself" out in the past to be very intriguing. Not too many options...could a valve have somehow fallen down into a cylinder? I've heard of valve seats falling out...but would that intefere to the point of jamming the engine?
