Hey guys, I just probed my 02 sensor on my 91 GT (it has ODB1 and I was probing the o2 sensor on the exhaust manifold).
Anyway, I got NO READING from it, and ever since I bought the car, the "check engine" light has been on. I was told by the owner that she was told it was a problem with the o2 sensor in the engine... well the exhaust manufold o2 sensor is the only real o2 sensor I know of... any I probed it and sure enough it´s dead, at least it looks dead from the (lack of) voltage reading Im getting from it.
I just wanted to verify that this was the problem, because I´ve been having this one kinda weird idle problem:
- when I let it idle, then give it just a tiny bit of gas (just to push it off balance a little), the rpm won´t drop back to normal rpms, but it will drop BELOW normal rpms, then back up to normal. It takes about 2-3 seconds for this whole process to happen, and sometimes it drops really low, to the point of almost stalling the engine. Would the 02 sensor have anything to do with this? (I was personally thinking that the ISC valve was the problem, but this o2 sensor may be causing this problem too I guess...)
anyway thanks for any input :-]
