Daytime Running Lights and Fog Lights not working | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by firedawgy, Mar 27, 2005.
  1. firedawgy
    firedawgy New Member
    51
    S.C.
    Do we have daytime running lights on our ZX's? I have a 99 and my fog lights don't work and the book says that the fuse is shared with the daytime running lights. The fuse is fine and the driving lights are new, but still nuttin. Any suggestions. Thanks yall
  2. 4d_Me
    4d_Me FEOA Member
    489
    266
    Chandler Az
    check your grounds to make sure that they have not come disconnected, and you might ask bigreacefan cuz he just had the same problem, hes probly pritty familer with the wireing!!!!
  3. inis
    inis FEOA Member
    316
    166
    no zx2 has daytime lights
    it wasn't even a option
  4. Mustang13
    Mustang13 New Member
    New guy yere - I am from Canada - now have this exact problem - up here DRL's are manditory. Any help from anyone who has had this issue would be great!
  5. Macker007
    Macker007 Guest
    4
    Add me to the list with this exact problem. And yes, DRL's are mandatory in Canada.
  6. masm60
    masm60 Guest
    15
    I have a '98 and there are no DRLs. Fog lights only work when the headlights are turned on though. When I first got it I thought they were not working.
  7. silverton
    silverton FEOA Member
    2,719
    288
    Seattle, WA
    Just to pipe in. Even if your car doesn't have DRL, you'll have the fuse for them. My car doesn't have power windows, locks, or sunroof, but I have the fuses for them. As long as it was a factory option, the means of it to work will be there.
  8. ZX2Fast
    ZX2Fast New Member
    492
    8
    Indiana
    Strangely, the DRL relay power is drawn from the 10A DRL fuse. But, the power to the DRL's is drawn from the 10A FOG fuse. Check both fuses. Since each DRL is controlled by its' own relay, and you have issues with both, then the problem has to lie in a shared connection. You may also want to check the DRL resistor (if replacing a blown fuse isn't the issue) to make sure it still has continuity and the wires aren't melted.
