Dave94LX wanted to see my new EGT engine | Page 3 | Ford Escort Owners Association (FEOA)
Discussion in 'General Discussion' started by BOSS302man, Mar 22, 2010.
  1. ALIEN3T
    ALIEN3T New Member
    1,359
    buena park ca
    Needs a drop and a tint
  2. Bear45-70
    Bear45-70 New Member
    411
    Union, Washington
  3. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    hehehe, Hugh needs to lay off those 7am beers!
  4. BOSS302man
    BOSS302man FEOA Donator
    2,665
    44
    198
    Lebanon, PA
    Got some of the braces and supports in. here, we're test fitting the engine to the mtor mounts.
    [​IMG]
  5. racerboy
    racerboy FEOA Member
    773
    168
    Sheboygan, Wi
    Looks like a VERY tight fit, lol!
    How are you going to fit headers in there?
    By the way, I found the actual specs for the 427 SOHC engines. They're from "The Standard Catalog of Ford" by John Gunnell. I'll type out exactly what the book says about them.
    The code L's (the least powerful one, with a single carb) specs are:
    "SOHC 427" 4v V-8: Overhead Valve. Cast Iron Block. Hemispherical combustion chambers with overhead valves and overhead camshafts for each engine bank. Displacement: 427 cid. B & S: 4.23 X 3.78 inches. Compression ratio: 12.10:1. Brake hp: 616 at 7000 rpm. Five main bearings. Carburetor: Holley four-barrel. Cooling system capacity: 20.5 qt. with heater. Crankcase capacity: 5 qt. (add one qt. with new oil filter). Dual exhaust. Code L. (This engine was available only "over the counter" for $2500).
    The Code M's (the more powerful one, with dual carbs) specs are:
    "SOHC 427" 4v V-8: Overhead Valve. Cast Iron Block. Hemispherical combustion chambers with overhead valves and overhead camshafts for each engine bank. Displacement: 427 cid. B & S: 4.23 X 3.78 inches. Compression ratio: 12.10:1. Brake hp: 657 at 7500 rpm. Five main bearings. Carburetor: Two Holley four-barrel. Cooling system capacity: 20.5 qt. with heater. Crankcase capacity: 5 qt. (add one qt. with new oil filter). Dual exhausts. Code M
  6. Dave94LX
    5,787
    238
    Under the Stairs
    Hey Randy, I had forgotten to respond to the pic you sent the other night. It looks like it will just barely fit in there. I am sure you guys will make it work though. Keep up the good work!
  7. Bear45-70
    411
    Union, Washington
    You can add 515 FT/LBS of torque @ 3800 RPM for the "L" motor.
    The "M" motor was 575 ft/lbs of torque @ 4,200 rpm.
    The engine weighed 680 lbs.
    The "M" motor cost $2350.00 in October of 1968.
    The engines also had a dual-point distributor with a transistorized ignition amplifier system, running 12 amps of current through a high-output ignition coil.
  8. 88scortgt
    88scortgt FEOA Member
    750
    166
    Elkhart, IN
  9. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    No, not right now, but thanks for thinking of me.
  10. Dave94LX
    5,787
    238
    Under the Stairs
  11. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    Videos don't do this thing any justice at all!
  12. 98EscortDude
    98EscortDude New Member
    1,790
    Vermont / Western NC
    Now you're just teasing us with those videos. I wanna see that thing opened up.
  13. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    I'd like to get a burn out done soon.
  14. Dave94LX
    5,787
    238
    Under the Stairs
    I'll bring my camera the next time I come up, to get some video for you.
