Here it is Dave:
I believe that was the one 4 barrell version. I'm pretty sure the 2 x 4 barrel version was 650 or so. This engine is the 2 4V. The extra carb added 50 HP. You could be right about the torque, I always thought they were 50 less on the torque than HP.Bear45-70 said:Ford's 427 SOHC were rated a 616 horsepower @ 7000 and 515 ft/lbs @ 3800.
True that is for the single 4 barrel engine. The 2X4 barrel engine produced 657 horsepower @ 7500 rpm and 575 ft/lbs @ 4200 rpm.BOSS302man said:I believe that was the one 4 barrell version. I'm pretty sure the 2 x 4 barrel version was 650 or so. This engine is the 2 4V. The extra carb added 50 HP. You could be right about the torque, I always thought they were 50 less on the torque than HP.Bear45-70 said:Ford's 427 SOHC were rated a 616 horsepower @ 7000 and 515 ft/lbs @ 3800.
