1 - 2 of 2 Posts
So I need to find a camshaft for my 89 lx 1.9 cvh motor. I found one that fits in the mk1 1.6 by Kent cams, does anyone know if that will work? If not can someone point me in the right direction to find one that does
a 1.6l cam has bigger journals and flat lifters so no. Ring up crane cams they can re grind your stock cam, just make sure you let them know its a CFI cam. 89 should have roller lifters. Don't go crazy unless if you want trouble finding valve springs.
A better lest costly option is a stock HO cam.
1 - 2 of 2 Posts
