has anyone built a custom intake? if so, how did you make it? and what did you use?
slammineon95 said:what kind of car would you take the tube off of it for it to work?
You can find these at autozone or other cheapy car parts stores for... Well, cheap. I've heard some people needed to move their battery though. Basically all CIA's are the same, just rig it so it'll fit and doesn't leak. Play with it a little, you're not going to hurt your car if you mess it up as long as you don't /drive/ it around a lot like that.coyote-x said:You can use a Civic tube and some flex pipe, buy PVC and mod that to fit, or get an intake off another car and clamp it on and set it down in the wheel well... Easiest thing to do to your car.![]()
