Has anyone relocated their cruise switches? I want to run a smaller dia. wheel and still retain the cruise ability. I have so far cut out the brackets for the switches from a donor wheel cover and stacked and bondo/fiberglass the switches together. I plan to relocate the switches to center console. I need to look up wiring diagram and see if the clockspring can be removed from the circuit. So far so good, but getting a good finish where they are going is proving difficult. I attempted to cut the vinyl precisely to fit with a tight seam, but the angles of the switches is making a smooth joint difficult. I made a mold of one of the switches to try to fab. a cover/ faceplate to mount into console.
