Hey everyone!
So i recently received a ford escort SE SOHC 2.0L, from my father to try to learn a little bit about cars, and fixing them.
Originally he was told the issue was a fuel pump, so i went and replaced that, and the filter. No start, but cranks.
I ended up replacing a few other things like :
Spark Plugs
Spark Plug Wires
Crankshaft Position Sensor
Fuel Pump
Fuel Filter
i did a few tests, Compression test on cylinder 4 (Receiving zero compression), not sure if i tested it correctly.. I removed all the spark plugs, and wires, disconnected the fuel injector and fuel pump relay/fuse under the hood. In some videos and threads they say to crank it 4-6 times and to see where the gauge points to, but when i try to turn the key, it just sounds like 1 continuous crank. Not sure if this is user error, or a engine issue. i have yet to try testing the other 3 cylinders. When the spark plugs are in, it cranks over like normal, just when no spark plugs are in, and the compression tester is in, that it sounds like that continuous screech.
I've tried putting starter fluid past the throttle body, and that did not start the car aswell.
I've used a inline spark tester, and that turned out to be fine on all 4 cylinders.
I also am receiving good pressure from the fuel rail schrader valve.
My only idea is maybe a timing belt? Am i missing anything else? i did notice a tear in the PCV hose to the right of the valve cover, not sure if that could possibly prevent a start. My dad thinks also maybe the fuel pressure sensor/regulator? but i figured if starter fluid wouldnt start it, then it must not be a fuel issue.. either spark or engine. Looks like the inline spark test was fine, so my only idea is engine.. unless im missing something? T_T
Any information would be greatly appreciated... i've been stuck and dumbfounded for a while now, and could really use your guys help!
Thank you so much!
Spark Plugs
Spark Plug Wires
Fuel Pump
Fuel Filter
Thank you so much!
