Hey, all!
My 93 1.9 LX wagon isn't starting. It's cranking just fine, but I don't hear the fuel pump priming with the key in the "on" position, and it doesn't start.
I'm trying to figure out if this is actually a problem with the fuel pump, or if the problem might be happening earlier in the system. I'm kind of suspecting that there is no power going into the fuel pump circuit at the very beginning of the power supply. Here's why:
1) My Heynes seems to suggest that the "Fuel Inj." fuse inside the fuse box under the hood by the battery tray should be hot at all times, but I removed the fuse and hooked up my multi-meter to the pins that go into this fuse, and I couldn't measure any voltage. Am I doing this wrong? This is what I measured:
2) I tried to jumper the fuel pump by grounding the test connector in the engine bay. This should force the computer to turn the fuel pump on at all times (says my Heynes). That didn't happen, so it seems that either the pump or the electrical circuits that activate the pump are bad. BUT: I tried to run a KOEO test, and nothing happened with that either. I heard no relays clicking and got no codes, so it seems that the test connector might not get any power either?
Everything else seems absolutely normal: Lights work, the radio works, seat belts work, dash lights work, the car cranks strongly.
Am I testing this right?
What might cut off voltage to the "fuel inj." fuse AND to the test connector???
I'd be incredibly grateful for any input. Electrical issues are always a bit nerve wracking for me. I just don't seem to quite get how to troubleshoot them...
___
EDIT FOR THOSE RUNNING INTO SIMILAR PROBLEMS:
My issue was a blown 15A "Engine" fuse in the fuse panel inside the cabin (driver's side under the dash board). Then the question is: What's blowing that fuse? I personally found a short in the fan relays under the air intake, but to my knowledge, it could be a short anywhere in the ignition circuit, so almost anywhere. And there could probably be a number of other issues causing the engine fuse to blow?
- "Cooling fan" relay had three pins that are hot at all time, one has no voltage.
- "Fuel inj.", "Head" and "Cooling fan" fuses all have no voltage with either key off or key on.
- "BTN" fuse has one pin that has battery voltage with key off, and 7.5V with key on.
- I didn't check the "main fuse" because I wasn't sure if it was safe to unscrew that one.
___
