1 - 5 of 5 Posts
Where is the cam position sensor located and who do you replace it?
The cam sensor is on the front driver side of the head and you replace it by removing the one screw that holds in in. It is likely the cam sensor is not the issue. I'm guessing you got a code P0340 or P1381?
Ya the code was P0340. The code only comes up once and a while. Then disappears.
It just randomly stoped actting up.
1 - 5 of 5 Posts
