I have a 1997 Ford Escort. My problem started out with the car acting cold natured. Trying to die when it was cold and progressively got worse.
Now it is running the fan and fuel pump with the key off and stops running them when we turn the key on. It idles rough and dies but always starts right back up and runs good for 5 - 20 seconds then starts all over again. If I kep messing with it and get it to run 45 minutes then it runs perfect like nothing is wrong. We took it and put it on a scanner it showed code po135 o2 sensor heater circut malfunction replaced the o2 sensor no improvements.
We have replaced the PCM, CCRM,(both from salvage yard) and the o2 sensor(new) .
Any help would be appricated. I am at my wits end.
