Engine - Coolant leak into the exhaust manifold | Page 11 | Ford Escort Owners Association (FEOA)
Engine Coolant leak into the exhaust manifold
Discussion in 'Tech & Repair' started by zzyzzx, Apr 4, 2019.
  1. rbailin
    rbailin FEOA Member
    1,238
    372
    333
    I would strongly consider bringing the head to a machine shop and having it milled as little as possible ( < .003"). I can't tell from the excellent close-up photo whether there's minor pitting or if it's just dirt. But I figure that the milling cost is about the same as the cost of a new head gasket plus bolts plus your time to re-do the job. You could also get an opinion on the exhaust manifold.
    denisond3 likes this.
  2. zzyzzx
    14,999
    1,167
    It seems to be cleaning up nicely. The bottom is not warped or anything, but here is a closeup of the problem areas (circled in purple) with some pits that I feel are potentially the real problem. I should clean them out and infill with JB Weld or something else that can take the heat:
    [​IMG]
    That bolt hole in the lower left corner of this picture is where the broken bolt was. Otherwise I am not sure if these two spots are really close enough to anything to warrant any attention.
  3. zzyzzx
    14,999
    1,167
    Exhaust manifolds are still available new for these cars, and the cost would be about the same as milling one, or close enough.
    [​IMG]
    ATP 101244 $64
  4. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,343
    1,065
    Vancouver Island, Canada
    If the problem areas don't connect anything to anything they shouldn't matter. Look for pits or low areas connecting the water passages or "fire ring" of the head gasket to each other or other passages.
    The mark from the old "fire ring" comes really close to the coolant passage, but doesn't quite enter it, so that part is okay.
  5. zzyzzx
    14,999
    1,167
    OK, so you are saying that I can ignore the places circled in purple, and concentrate on inspecting the places circled in red:
    [​IMG]
    If so, that seems like a not optimal design, or casting.
    the cylinder next to it is almost as bad.
    Having said that, it seem prudent to fill in the places circled in purple as shown here:
  6. denisond3
    10,017
    2,759
    Do you know if that head had already been milled?
    austin86 likes this.
  7. zzyzzx
    14,999
    1,167
  8. Joey_Twowagons
    2,343
    1,065
    To me both the red and purple circled areas are okay, just barely since the sealing parts don't quite extend to the erosion and water passage.
    Ford permits only a really tiny amount of material permitted to be milled off. I am guessing that this may be due to the fact that removing more will increase the compression ratio more than an allowable limit, and the same for the camshaft timing.
    The emissions approval might have demanded very tight tolerances for these.
  9. rbailin
    rbailin FEOA Member
    1,238
    372
    333
    If the head was previously milled, the machine shop should have stamped the amount on the outside of the head, usually near the camshaft gear (e.g., "003"). If it was warrantied, there should also be an overheating indicator attached in the same place.
    Felpro sells a copper shim spacer for these engines to compensate for removing a lot of surface material from the head or block. On the head, there are shallow depressions on the intake side to indicate the maximum amount that can be removed.
  10. zzyzzx
    14,999
    1,167
    I put one of the bolts through the cylinder head and counted 17 threads sticking through. I can easily run the bolts down into the engine block 19 threads. Not taking into account the size of the head gasket (around one complete thread) I have no idea if this enough of a margin then torqued down, but I certainly hope so.
  11. denisond3
    10,017
    2,759
    Im sure it will be. The bolts dont stretch even as much as a single circle of the threads.
  12. zzyzzx
    14,999
    1,167
    Still haven't put it back together yet, but when I compare the old Fel-Pro gasket to the Mahle that I bought, the cylinder openings on the Fel-Pro are a few mm bigger in diameter to the point where I wonder how it could have possibly worked! I mean, the cylinder openings on the Fel-Pro are that much bigger than the cylinders themselves.
  13. Joey_Twowagons
    2,343
    1,065
    I checked Rockauto, and the Felpro head gasket is listed to fit from 1981-99 Escorts, i.e. 1.6, 1.9 and 2.0.
    The 1.6 has a bore of 3.15", 1.9 is 3.23" and 2.0 is 3.34".
    So obviously if the gasket fits the 2.0 (including overbores) it is going to be pretty sloppy on the earlier, smaller bores.
    Someone brought up the subject of the head gasket bore a couple years ago, so I did a bit of checking on the Rockauto site and ordered a few "manufacturers closeout" gaskets that were listed only for the 1.6, to use on my bigger bore engines, as I think it is better to have a gasket bore closer to the cylinder bore size.
    Felpro is presumably trying to save money by only making one gasket for several engines. I also found that their valve cover gasket didn't fit so well on my 1.9 SEFI engine, at first I thought for the same reasons. However Rockauto shows their VC gasket as only fitting the 1991-96 1.9 engine.
    I checked the Mahle HG listing on Rockauto, and sure enough, it shows an application only for the 1991-96 1.9 engine (although I don't know why it won't work on the first generation 1.9).
    rbailin and zzyzzx like this.
  14. zzyzzx
    14,999
    1,167
    Removed the oil dipstick tube to make it easy to reinstall the cylinder head.
    Now how do I get the dipstick tube back in?
    it doesn't seem to want to go. I think it's because the intake manifold is in the way. Presumably it can be done with that installed?
    It was easy enough to remove.
  15. Joey_Twowagons
    2,343
    1,065
    All I can suggest is to clean it well with fine steel wool or similar, and put a thin layer of grease on it to help insert. But make sure it's aligned correctly before pushing too hard.
  16. zzyzzx
    14,999
    1,167
    What's the correct alignment? I suspect that is the real problem.
  17. denisond3
    10,017
    2,759
    I think I was able to push the dipstick down into the block, with its top end sticking out from between the central space between the inlet tubes. But Im not above bending it a little bit to line up.
  18. zzyzzx
    14,999
    1,167
    Got it in. Wire wheeled the tube near the bottom, then greased it. Then stuck a stubby Philips head screwdriver into the top part and pushed down. I hope the lack of RTV doesn't cause a leak.
  19. Joey_Twowagons
    2,343
    1,065
    Good to hear. I am sure there will be no problem with leaking, as the joint is well above the oil level and the crank case is generally under a slight negative pressure due to the PCV system.
  20. zzyzzx
    14,999
    1,167
    Update after driving it for around 1K miles:
    The car runs and drive fine. The two oil leaks that I attempted to fix, at the valve cover and oil pressure sending unit are no longer leaking. The parts of the engine that were formerly coated with oil by those leaks are way cleaner than I am accustomed to seeing them. There is still oil leaking from something, probably the oil pan or maybe something under the timing belt cover, but that is something that I will possibly deal with later (some of that area was messed up with oil due to the valve cover leak, so I won't know if it's the camshaft seal or crankshaft seal until I remove the timing belt cover, and I don't feel like doing that until I need to change the timing belt or water pump). Presumably I am leaking less oil overall, but I never measured it before.
    I do have some new leaks. One being a refrigerant leak mentioned here:
    https://www.feoa.net/threads/help-me-identify-the-exact-source-of-this-leak.114764
    And a coolant leak at a freeze plug in the front of the engine. It's reasonably small and I am going to try 2 stop leak pellets on my antifreeze when I replace my thermostat and hopefully that stops it. Otherwise, unless it gets worse, it's not worth fixing since the amount of antifreeze I have added is actually pretty small. I would probably have to remove the catalytic converter to fix it, or maybe that A/C hose that's in the way. The freeze plug in question is not behind the catalytic converter, but more like between the catalytic converter and the lines for the A/C. This is the type of thing that I really want to put off since if I can verify the source of the oil leak and it's the oil pan, I would do that and fix the freeze plug at the same time. That and I have never had a freeze plug leak before and have no idea how hard that is to fix even if one has access. It's possible that this leak isn't particularly new, just masked by previous leaks.
