A few weeks ago,when checking my trans fluid in my 1995 automatic i noticed some moisture on the dip stick.Ive been wanting to do a fluid/filter on it for quite some time.So I d ropped the pan,drained it, and notice some milky foam comming from the front of pan area after it was draining for a while..Put the thing together.Had some problems a week later with it slipping so i dropped the pan again..Same milky foam from the front of the trans area.Could this be condensation?My guess its coolant.But why would it be showing up from the front of the trans area?There was also a little in the bottom of the pan.Whats the possibility of the cooler in the rad leaking?Would a rad pressure test indicate a leak there?Any imput appreciated.Thanks
