Ok, I´ve asked a couple of q´s about high idle thanks for your responses. Here is what I´ve found. The car warms up and everything is normal, then at a certain point the idle jumps up 400-500 rpm above normal idle. I can dis-connect the tps, o2 sensor and idle speed control valve and nothing changes. Rpm and driveability stays the same like the computer doesn´t react to any changes. Everything in the vehicle works like normal accept the cooling fan only will work with the key turned on. Is the computer bad? Or is there a relay that could have gone out that only controls the computer? Where is the best place to get a new computer? Thanks for any help you might be able to give.
[ This message was edited by: SHughes on 01-05-2003 11:17 ]
