compression test? | Ford Escort Owners Association (FEOA)
compression test?
Discussion in 'General Discussion' started by Chriskory, Jan 6, 2004.
  1. Chriskory
    Chriskory Guest
    16
    what is good compression for an escort GT
    each cylinder should read ...what
    whats its overall compression
  2. Whig-It
    Whig-It Guest
    239
    i have seen in the 150-170's that is what most people say, What you want is all the cyclinders to have the same, or around the same reading
  3. Chriskory
    Chriskory Guest
    16
    so each one should make 150 or so
    or should tehy add toghether to equal 150
  4. TitoElSpicco
    TitoElSpicco Guest
    1,078
    each cylinder should be between 150-160.
  5. James92Scort
    James92Scort Guest
    8,915
    5
    with the lowest reading cylinder no less than 75% off of the highest reading cylinder.
    160/160/135/160 would still be acceptable, but I'd check out that #3 cylinder for safety's sake.
