Compression test weiscos | Ford Escort Owners Association (FEOA)
Discussion in 'Forced Induction & Nitrous' started by uglyducklingescort, Nov 26, 2008.
  1. uglyducklingescort
    uglyducklingescort New Member
    997
    Tulsa, OK
    Assuming the different material and having the rings filed to weisco's specs on rebuild will my compression numbers be lower when the engine is dead cold? If so how much lower than it might possibly be when warmed up due to therman expansion, 8.5-9.1 to 1 compression. BP05 Head. I never did a compression test after the rebuild and the number looked low around the 120's with the engine turning 5 or so rotations. Is cold out and I only did one piston #1.
    -Steve
  2. vtec-this
    vtec-this FEOA Member
    1,577
    6
    288
    Brampton Ontario
    stock head gasket and combustion chambers?
  3. LilBigMec
    LilBigMec New Member
    185
    Moose Jaw, SK S6J 1C6
    While it's always best to do a compression test on a warmed up engine, you probably won't see much more compression out of it when warmed up. How many miles do you have on the engine since the build? Did you do the test just for sh!ts and giggles or do you think there is something wrong with it?
  4. uglyducklingescort
    997
    Tulsa, OK
    gits and shiggles..... I have no problems with it. As for it warming up why would there be little or no difference? They are aluminum. As for head gaskets and head yes they are all stock.
    -Steve
  5. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    steve that sounds a little low
    you did have the throttle wide open when you did the test, right?
  6. uglyducklingescort
    997
    Tulsa, OK
    LOL no......
    :beer:
  7. therieldeal
    8,622
    19
    338
    Northeast CT
    haha well give that a shot..
    also, forged pistons tend to expand more with heat than cast pistons. thats one of the reasons they arent generally used in factory applications... the additional clearance needed results in more piston slap noise when the engine is cold.
    i say warm it up first in order to get an accurate comp test.
  8. uglyducklingescort
    997
    Tulsa, OK
    Yeah I figured it was just a question. It runs fine otherwise.
