it's all good dude.
you need to re ring your engine and reseat your valves and top it off with all new gaskets, oil pan, front crank seal, cam seals, just overhaul it, prolly a great idea too to have the crank machined and do those main and rod bearings, just overhaul it, cams and cam bearings shouldn't need to be touched they hold up good and last forever but rings, bearings, and reseat your valves with new stem seals.
