1 - 10 of 10 Posts
say, what is the story about the cold air intakes for the 2nd gen LX escorts? i dont hear too much about them, and rarely i ever see anyone with one (especially on cardomain). like, do they even make them for the LX, or would it have to be all custom work?
please, lemme know what you guys know.
i dont really know much about it, ive seen some escorts using a
Weapon R intake, dont know much more about it. hopefully someone else does. I know that Weapon R has a site, dont know what it is. I dont even know if its for the LX or not.
The only cold air I've ever seen on a 1.9 has been fabricated. It's extremely easy to do after you have the standard conial filter which they DO make for the second gen LX (www.nopi.com) After you've got that, it's all about fitting a curved piece of tubing on there :p Okay, so it's slightly more complicated, but not much. It makes a suprising difference. The conial filter makes a huge difference in and of its self, but the cold air extension makes even greater a difference. I'll try to smack my digital camera up and get her to take some pictures for you so I can show you how my friend and I fabricated it.
Hello:
Could anyone explain the advantage of the conical filter
over the stock one?
I have the following questions:
1. How should I maintain such a filter
- is it cleanable or just disposable like the stock?
- if it is disposable then how often one should replace it?
- what manufacturers, types, sizes are preferable for our cars?
2. Is cold air intake just and extension of the filter to the
fender well?
- if so then would the cold air intakes for zx2 from www.zxtuner.com
work?
3. What are exactly the performance gains you really experienced
Thank you,
Rob
some are both
replace it once its gets dirty, just like the stock one.
k&n is very good but a little pricy, but they are all pretty much the same.
fender well?
cold air is just as it sounds. cold air. you can achiveve this by going into the fender and sucking in cold air or you can have aluminum tubing in place of you rubber tubing which will help cool off the air and let the air flow more freely.
work?
couldnt answer that 1 for ya.
typically gains are anywhere from 4-8hp... which isnt bad considering you can get the pieces and make an aluminum cold air intake for under $150 easily.
hope that helps.... and please correct me if im wrong people
1 - 10 of 10 Posts
