P1443 Evaporative Emission Control System Control Valve
P0136 02 Sensor Circuit Malfunction Bank 1 Sensor 2
PO141 02 Sensor Hdeater Circuit Malfunction Bank 1 Sensor 2
The 02 sensor codes are for the post catalytic converter sensor. It is located in the exhaust pipe underneath the car. The number 1 sensor is up under the hood near the catalytic converter. After the problems have been repaired the check engine light will go off after a while or you can disconnect the battery for a few seconds and that will turn it off.
