Code P0340 | Ford Escort Owners Association (FEOA)
Code P0340
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by nitrodave911, Apr 23, 2010.
  1. nitrodave911
    nitrodave911 New Member
    Replaced the timing belt 2-3 weeks ago. Car ran good since. All of sudden it started to run rough and check engine light came on. It is P0340. I replaced the cam sensor but it did not correct the problem. Timing belt looks good and tight so I can imagine it could jump a tooth since it ran fine for awhile. Any place to check or look at next?
    Does the car need to be driven after the cam sensor is replaced? I cleared the code and ran it high idle for awhile but did not drive it.
  2. madmatt2024
    madmatt2024 FEOA Member
    9,895
    424
    383
    Upstate N.Y.
    You should drive it after you cleared the codes and repaired the problem.
  3. nitrodave911
    update
    Alright I replaced the coil pack as well and took it for a drive. The check engine light does not come on but it throws a code. If you erase it and rescan it comes right back.
    The car has no power and feels very sluggish. Also when it does not want to shift when it should. When you come to a stop the RPM is all over the place and acts like it is very close to stalling out.
    Could the Throttle position sensor be the problem? Any other ideas?
  4. pextor
    pextor Moderator Staff Member
    6,011
    842
    Lancaster, pa
    sounds like you skipped time. the tensioner probably isn't set tight enough.
  5. homestead367
    homestead367 New Member
    516
    Indianapolis
    I had that happen after I had my timing belt replaced. But i reset the code and it ran normal with no codes again.
