rjkardo said:
I am a bit confused...
Should I replace:
• DPFE Sensor (Also called the Back Pressure Transducer (BPT).)
• EGR Vacuum Regulator (EVR) Solenoid
• EGR Valve
Also, is there a how-to on searching for vacuum leaks?
Sorry, am trying to learn. I have been searching the forum but a lot of the comments are either confusing or lacking the details that I need.
Thanks,
Rod
Are you sure it's not code 1337? Because if it was, that would be sweet and I wouldn't fix it just so I could keep that code!
rjkardo said:
I brought it to an O'Reilly's. They have a code reader that does both ODB1 and 2. My car is a 1, and it gave the code as 337, so I am sure.
I get your point about 1337 though...
In all seriousness though, there is no "replace this to fix code 337" rule book. The problem really does need to be diagnosed, and this is where you have to do a little work.
Start it up, let it idle. Remove the vacuum hose from the EGR valve. Does it have vacuum? If so, then replace the EGR solenoid because it should not have vacuum at idle.
rjkardo said:
Here is where I need some help. Sorry for being such a newb...but I am trying to learn...How do I know if I 'have vacuum'? I am not sure what you are meaning by this...
Again, I appreciate the help and am trying to learn, but I am not sure what you are meaning here and in other spots.
If not, then apply vacuum to the EGR valve. It should start to idle rough and perhaps even stall. If it does not, then either the EGR valve itself is frozen up, or the EGR ports are plugged up. Removal of the valve at this point would be required for further inspection.
rjkardo said:
How do I 'apply vacuum'?
My guess is to put my thumb over the hose...is that what you mean? Close it off?
If the engine does try to stall, then the EGR valve and its plumbing is OK. At this point you'll want to remove the PFE hoses from the sensor and start the engine. There should be exhaust coming from both of those hoses (one slightly stronger than the other). If you are getting nothing then remove the hoses from the exhaust and check for flow there. It might be plugged up with carbon.
rjkardo said:
If these are ok, then remove the PFE sensor and make sure it's not all plugged up where the hoses attach. Carbon can get up in there... water can get up in there.. rust can get up there.. and the hoses themselves can deteriorate and flake apart on the inside and clog up that sensor as well. If you find debris, try cleaning it out..
rjkardo said:
Otherwise, most likely the PFE sensor itself is bad. I ALWAYS recommend replacing the hoses at the same time... it's cheap insurance.
rjkardo said:
Yes there is a slight chance that it could be a bad wire somewhere or even a bad computer, but this gets into further electrical testing...
