Hey, Well Just recently I've been having Problems with my 1994 Ford Escort Wagon 5 Speed. 40.1k Miles original Miles on Everything. But just recently, Mostly when it started getting around 30 degrees outside, when my Car is cold, It wont shift. I have to let it warm up for a few minutes, Yesterday I flushed the tranny and put new fluid in. Still does the same thing, Even while moving and being warmed up it will still do it, Won't shift. Unless the Car is at high Rpms. The clutch however isnt slipping, Nor grinding when going into gear, but shifting has been alittle rough, Its deffinately not butter. The clutch pedal feels alittle mushy, But gets pressure back up while shifting at high rpms. I really have no experience when it comes to clutches. Maybe the Cable needs to be adjusted? I have nooo clue.
And, I have no idea if this has anything to do with it. But For example, I can be in first, Mash on it and it will accelerate. While doing that, My clutch has full Pressure, Like it always had, I can barely press it and The Rpms will shoot right up, Because im disengaging the Clutch, Which means that my clutch is working fine. Im quite a newbie when it comes to Clutches. I need advicee!
