1 - 11 of 11 Posts
That´s assuming by "clears" you mean clear corners to replace the amber front turn signal lenses on your scort.
If you want clear tailights or altezzas, well no one makes them as of now. They are supposed to be coming out soon for the 2nd gen hatchbacks, but probably not for the 4dr sedan unless a lot of people express an interest. There´s a post on EscortRacing about it.
procarparts.com. They sell them with the amber bulbs. The only problem is that they are styled for the 94 and up scorts. they fit the openings but the wiring harness is bigger in the 94 and up. So either you get a harness out of a 94 and up or you can do liek i did and jam the bulb in the hole. it doesn´t move at all.
1 - 11 of 11 Posts
