1 - 7 of 7 Posts
could you give a little more detail about your car and the problem that you are experiencing??? Did you clear the code after you replaced the parts?? My Girlfriends Echo had the Engine light come on and there were 3 codes all dealing with the EVAP system, turns out there was a vacuum hose that was disconnected. reconnected it, cleared the code and it never came back.
Check engine problem 2
The code was cleared after the part was replaced.(EVAP solenoid) About five days later the light turned on again and scanner pointed out the same code previously repaired, code was cleared again but few days later turned On again, still on.
Thanks for your help.
Vac hoses, Vac hoses, Vac hoses.
If it's a 1.8, that's all I can say. If it's a 1.9, let me know and I'll tell you about the more frequent vac hoses (EGR and emissions related) that tend to go. Been there, done that, stupid hoses.
Matt 8)
hey man if you know what it is and you fixed it and it still gives you the same code take the pos + off the bat than for 10 20 sec but it back on and it will be gone
hey man if you know what it is and you fixed it and it still gives you the same code take the pos + off the bat than for 10 20 sec but it back on and it will be cone
1 - 7 of 7 Posts
