chances are the connector is melted. Using the wrong bulbs will cause this. If they are melted, fix the plug end by replacement then go back to using bulbs more closely matching what the factory had initially installed
There is nothing melted at all and the bulb is the original that was in there when I bought it as a unit off of Ebay. I will take a closer look at it today since last night I was trying to look at it in the parking lot of a grocery store with a flashlight.chances are the connector is melted. Using the wrong bulbs will cause this. If they are melted, fix the plug end by replacement then go back to using bulbs more closely matching what the factory had initially installed
Correction. Some char and melting has actually been located. But remember that this came from the original bulb that was supplied with the unit and it is in fact the correct part number at least...chances are the connector is melted. Using the wrong bulbs will cause this. If they are melted, fix the plug end by replacement then go back to using bulbs more closely matching what the factory had initially installed
All I know right now is that with a new bulb in there the headlight is working great and also now seems to be brighter. When I first installed the new unit, it did not look very bright at all. So maybe somehow that Chinese bulb that was in there was defective and caused the issue. It was the right type of bulb but never worked correctly. But thankfully last night when I was driving home in the dark, my lights were nice and bright.chances are the connector is melted. Using the wrong bulbs will cause this. If they are melted, fix the plug end by replacement then go back to using bulbs more closely matching what the factory had initially installed
The thing is, that is the bulb that came with the unit and it was inside and sealed away from the elements. I don't know what was up with that bulb but I do know that it never really looked very bright. Even had a lady tell me that my headlight was not working right. Maybe it was the prong. Who knows? All I know is that now it is working much better.I don't see how you can blame the Chinese lamp assembly for the burnt up socket. Unless the prong on the Chinese lamp was super thin so didn't make tight contact with the plug?
As for the broken tabs on the plug, mine have been broken off for twenty or more years, the socket stays on just fine without them.
