how do I go about changing my manual gear oil on my 97 tracer...also, I do not have an owners manual, so how much do I need and what viscosity does it take? I'm assuming 75/90...
Original post: "how do I go about changing my manual gear oil on my 97 tracer". Yes, it also asks viscosity.EscorGo said:The original post also asks what viscosity to use. There's no risk in using ATF. it's the recommended fluid. Putting gear oil in a trans designed for lighter fluid will make it work harder than it needs to. The Mazda trans require gear oil.
EscorGo said:Geesh, what is your point?
I was just hoping someone would answer that part of his question. And I didn't appreciate you trying to correct me, obviously being wrong.
Oh please, give me a freakin' break!EscorGo said:Okay, one last time. In all fairness YOU should have added the word "also" in you post so as not to imply you were the only one who understood this thread. Read from the top and not out of context.
